18 volt solar battery charger | on ElectriciansForums
Discuss 18 volt solar battery charger in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Kathmandu
Hello, hoping for advice on this... We intend to use 18volt Makita power tools high in the Khumbu mountains near Everest. With no mains power on site I’d appreciate any advice on an affordable yet lightweight, portable and efficient set up to recharge batteries. Probably x10 4.00 Ah units per day. Plenty sun generally! Thanks in advance, Colin
You can get a Car charger for the LXT batteries... says 70W input and takes 80mins to charge a 4.0Ah battery and accepts 12-24 VDC... You should be able to find one or more solar panels to give you this... preferably with integrated charge controllers.
Reply to 18 volt solar battery charger in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Need to crack on to get most from this year :cool: BTW if you are thinking about adding to the strings later, i.e. add more panels to existing...
