180v between live/neutral but 240 between live/earth | on ElectriciansForums
Discuss 180v between live/neutral but 240 between live/earth in the UK Electrical Forum area at ElectriciansForums.net
kev.k
Manchester
Hi all
Downstairs lighting circuit isn’t working so tested voltage at each fitting and getting 180 live-neutral and 240 live-earth. Have checked continuity from board to each fitting and got a neutral all the way around the circuit so I’m a bit stumped on what the issue can be.
There is access from the board to under the floor boards upstairs so I can pull a new twin from the board and re wire the lights without any disruption or damage if I have to but hoping for an easier fix.
Any ideas?
You say you have a Neutral all the way around but in reality you haven't.
It's most likely a bad connection on the Neutral.
Have you tested L - N at a fitting with the light switched ON?
Have you tested L - N at the Consumer unit on the Lighting cct?
You may have 180v L - N on the meter but it's probably breaking down under load.
Results speak for themselves, obviously there is a high resistance in the N between the supply and the fitting.
Poor connection
Broken cable
Mouse problems
Incorrectly wired light fitting?
First look for a shiny new B & Q style light fitting somewhere
After that it is a logical fault finding approach, find the broken N.
Thanks for the help guys!
There was an old JB between the leg from board to the first light and was missing a screw from one of the terminals so someone had used insulation tape to connect the neutrals together which had eventually come undone. WOW! The neutrals were still barely touching, hence the continuity of the neutrals all the way around but obviously not enough to be carrying the current.
Thanks again
Thanks again
thanks for letting us know, and welldone for finding the fault.
Reply to 180v between live/neutral but 240 between live/earth in the UK Electrical Forum area at ElectriciansForums.net
My guess would be damp and corrosion somewhere is the cause. But same result as what James has said.
One of those backlight Chinese testers may have helped that’s if the tester didn’t catch fire or electrocute you. LED TV Backlight Tester 12W LED...
2 3 4 5
4K
