M
Mega Greg
Hi all,
I went out to a weekend call out where the customer had had a fluorecent tube and starter replaced. Apparently the light had shone brightly for a short time and then went out.
I opened up an outer piece of casing which revealed little more than a choc block. I tested for voltage and got constant readings of 18V LN and 10V LE (0V NE). There was no apparent means of openning up the lamp and not wanting to risk breaking an old fitting in the evening I am yet to look inside. fixed wiring (black insulated) seems to just reach the choc block from beneath the fitting with the white insulated wiring for the fitting on the other side.
Is there something basic I am missing here?
