18vdc convert to 12vdc | on ElectriciansForums
Discuss 18vdc convert to 12vdc in the UK Electrical Forum area at ElectriciansForums.net
Delboy247
Hi there anyone here know an easy way to convert 18v dc to 12v dc found a few items on flee bay but just thought if anyone can give me any of there thoughts thanks.
Tell you want I'm trying to do is run a Bluetooth adapter which needs 5v 1amp from a battery which is 18vdc 2.5ah I'm gonna hook up a ciggerate lighter plug it in a usb which I can customise just need to know how I can achieve this without melting anything looking around for a stepdown dc voltage is there anyway I can lower amperes or won't this matter as the usb steps it down further.
click where its highlighted in blue Votage Reg.pdf and zoom in till you see image
I'm using me iPhone just logged in safari I can see the pic mate great stuff so your saying I don't really need the capacitors but advise me to do so ill pop down maplin tomorrow just gotta find the soldering gun I know I got one somewhere thanks for ur help
Have I misunderstood something here. I though he needed no more than 3 amps, but minimum 0.5 ?? Might have mis-read it though. Not a problem cos obviously there's higher rated regulators around. Could the OP clarify? Daz
Reply to 18vdc convert to 12vdc in the UK Electrical Forum area at ElectriciansForums.net
Hi, I previously read this but can’t find it. I have drilled some holes but haven’t found it yet. Before I instal the wires I thought I’d check...
Depending on the specific battery you (intend to) buy, you might be able to just do Monster alternator -> LiFePo4 battery. The BMS for the fancy...
