T
Tynan
Hi there
New member here with a very basic question (I am no electrician!). :saddam:
I have a 19.2 V / 9000mAh battery (for an electrically assisted bicycle) and the wiring on the charge end needs a little attention. Basically one end of the battery gets plumbed into the bike and supplies it with power and the other end is the end that gets plugged into the charger when recharging.
At the charge end one of the wires is broken and needs soldering together, I am ok with the soldering / heat-shrinking and general repair duties but have zero knowledge of how electricity works with these batteries - so to my question . . . . .
When the battery is unplugged from the mains and the charger (and disconnected from the bike) is it safe for me to touch the red wire in this diagram ? (diagram below) ? To clarify I am talking about the red wire coming from the battery at the charging end, when the battery is disconnected from everything (from the charger / mains and the bicycle) is it ok to handle the red wire that protrudes from the battery ?
Thanks in advance for any help on this !!
Tynan.
OK I will try and give you opinion
The design appears to be poor,in that the charger trailing wires are permanently connected when the battery is fitted to the bike,I would have thought the battery housing should have a removable plug/socket arrangement at the housing
Soldering produces heat that will migrate upwards,when soldering try and keep the lead upright or use an heatsink near where the soldering is to be done
Dangerous voltages are 30 volt RMS (household type supplies) and 50 volts DC ( battery supplies)therefore your battery voltage is within that safe limit
Damage to the battery itself can occur if you inadvertantly short out an adjascent wire whilst soldering, by melting into the insulation,
Cheers for the reply Des.
I am not an electrician . . . . . or . . . . an illustrator ! :grin:
The diagram is for illustration purposes only, in reality the battery housing has a removable plug/socket arrangement, I've only draw the basic mechanics of the connections. (hope that makes sense)!.
Here's where the removable plug/socket arrangement lives (white cross)
Cheers for the tip.
Cheers for the info, so I should be safe soldering the broken wire when everything is disconnected ?
Once again, thanks for the reply, much appreciated.
Now please dont get me worried that I have given advise that could be harmful
The charger must not under any circumstances be plugged into the mains supply whilst soldering
Reading your post after you ammended the description.there is now suggestion in my mind that you may do this repair whilst it is still mains connected
You should be fine if everything is isolated and disconnected. Batteries can deliver many hundreds of Amps if their output is accidentally shortcircuited and this is a very real fire hazard. I would use a ferrule crimp and double heatshrink sleeve over it but solder would also work.
The battery will be out of the bike and disconnected from the charger, my concern was really getting some kind of shock from the battery itself.
I am super cautious in these situations, everything will be separated and covered/protected before I do anything.
I've not got a ferrule crimp unfortunately, but I'll use your idea of the double heat-shrink sleeve.
Cheers for the input.
Not to worry I wouldn't dare work on anything if it was connected to the mains ! You are talking to someone who dons rubber gloves to change a light bulb !
But thanks for your concern, I appreciate it.
...my concern was really getting some kind of shock from the battery itself.
If it's a straight forward battery with a 19.2 volt DC output then you won't get a shock from it.
The only down side to soldering is you'll need to check for sharp protrusions that might pierce the heat shrink. If need be you can always add a few turns of self amalgamating tape afterward for extra piece of mind.
"Batteries can deliver many hundreds of Amps if their output is accidentally shortcircuited"
Just to clarify: the wire I am looking to repair is the 'input' wire from the charger (rather than the battery's output).
Good to know !
I will keep an eye on that, I will remove the tips of any sharp burrs with a scalpel . . . . I've not got any self amalgamating tape, but I might grab some on Tuesday, thanks for the tip !
Unlike the charger, a battery doesn't have an input and output as such, just the + and - terminals. The wire you're working on is probably directly connected to one of the battery terminals. There might be electronics in between but assume it's connected directly to the battery and treat accordingly making sure you don't contact anything else accidentally.
Absolutely, I approach electricity with a lot of caution (hence my research on this forum before even thinking about repairing a simple wire break on a battery).
Cheers for the your input Marvo, genuinely appreciated if you never hear from me again please have the following inscribed on my grave:
He died doing what he loved: being connected to a 19.2 V / 9000mAh battery !
I'll report back if I survive.
Here you go . . .
It's basically a long battery that sits inside the frame of an electric bicycle, the connector broke and got pulled out of the end of the battery and although it still works fine it's getting damaged over time, so I am going to repair the connector - get it fixed back into it's rightful place on the end of the battery - but first I want to make sure the wires are all cleanly connected, shielded and secure before they get pushed back into the battery housing.
How do the wires terminate on the back of the socket, are they soldered or do they have push on connectors.
The wires coming out of the battery look like they might be long enough to trim the damaged sections and connect back on without an in-line repair.
Unfortunately they are soldered into the back of the socket ! Still, the in-line repair shouldn't be too taxing, even with my limited skills.
Quite a nifty looking bike. How long does it run for on a single charge and how much peddling do you have to do?
Yep, it's great fun for zooming around town, 15.5 mph top speed (20mph in non-E.U mode) . . .
Single Charge =
Around 20 miles range with pedal input.
Around 8 miles range with zero pedal input.
You can buy a newer Lithium-ion battery that ups the range and speed by around 20% (but it's a little pricey).
Full charge takes around 3.5 hours, simply plug it into the mains, you can throw the charger into your backpack/bag as it's very lightweight - and recharge wherever you find yourself.
Aint gonna put any usefull input here but think the OP should get a gold star for the diagrams alone... if everyone did this we would have a easier task with regards to helping them.
19.2 V battery question !!
Tynan,
Tynan,
