1A fuse in a 13A plug - what will happen? | on ElectriciansForums
Discuss 1A fuse in a 13A plug - what will happen? in the Australia area at ElectriciansForums.net
Discharged
I'm trying to explain to my kid (8) why were have fuses in plugs, and he found a 1A glass fuse lying 'round and he asked me if we could put that into a 13A plug. I said 'no' it would blow if you plugged into the mains.
Then I wondered if that really would happen... So thought I'd better ask here for clarification.
What does happen if you put a too-lower rated a fuse into a plug? To my mind, what happens depends on the appliance being supplied - what current it draws.
Any idea on this, please?
Well first of all it would depend on the load so if you put it in a kettle,iron,toaster,washing machine the fuse would blow but if you put it in a standard lamp it would work but when the lamp or bulb comes to the end of its life then it could blow the fuse
Yes but there is a catch you cannot use these glass fuses in a plug top you have to use the same type of fuse and these are rated as 1,2,3,5,10,13 amps but most common fuses used are 3 and 13 amps in a domestic property the 1,2,5,10 are more common in a worplace
So Kettle ,toaster,washing machine, would be 13 amps
Standard light, PC, printer,clock radio would be 3 amps
1amp fuses are used in 2 pin shaver adaptors but even then they are ceramic and not glass, glass fuses are used mainly to protect low current circuits on pcbs as far as i've found. Glass fuse in a plug with a faulty circuit might shatter the glass whereas the ceramic fuses contain the arc. If you powered say a vacuum cleaner or toaster with a 1 amp fused plug I doubt it'd even go bang it'd just melt the fuse element straight away. Interesting test all the same !!!!!
Hi,
It all depends on the prospective fault current and energy avaliable into a fault. A glass fuse can clear a fault of 35A and in practice a bit more, ok for the safety low voltage side of some power supplies. The test shown is a fuse subject to a current of about 6,000 amps and has a lot more energy avaliable!!
A glass fuse does not comply with BS1362 for a start so should not be fitted to a plug top.
Reply to 1A fuse in a 13A plug - what will happen? in the Australia area at ElectriciansForums.net
Yet another update: I believe what EDF have done is moved me from an Economy 9 to an Economy 7. I've just emailed them to ask if they can switch...
Hello oscar21, When I wrote about cables heating up I meant that IF a cable heated up that heat could not dissipate correctly if the cable was...
