1W LEDs glow slightly when switched off! | on ElectriciansForums
Discuss 1W LEDs glow slightly when switched off! in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
G
GB266
I have 1w LEDs in the hall and landing connected via two way switches. The switches are connected via a three core plus cpc flat cable.
When I switch off the light, the LEDs show a little glow all the time. Any ideas?
this is very common, normally if you use an energy efficient light bulb, its cause through inductance from the feed to the switch wire.
so i assume its the same thing happening with the led's,
ps it doesnt happen with the gls lamp
Reply to 1W LEDs glow slightly when switched off! in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I have three 6" LED wafers and a ceiling fan on the same circuit/switch. I wanted to control them separately, so I installed GOVEE smart lights...
Thanks again for your help, now solved đź‘Ť
