2/3 way Lighting and IR test | on ElectriciansForums
Discuss 2/3 way Lighting and IR test in the UK Electrical Forum area at ElectriciansForums.net
M
marshr02
Hi there. I know that in theory the IR test on a lighting cct requires all loads to be removed (ideally), and the 2 way switching operated and several readings taken - to ensure both strappers are tested. My question is on the logic behind the multiple readings. When the light being controlled by 2/3 way switches is ON, then in theory both strappers, plus the common are live - for a L/E IR test nothing has been missed. So once the lamps are disconnected prior to the actual test - I'm guessing it is assumed you will not know the state of the cct (would the light be ON if plugged in?) hence two tests with one of the 2/3 way switches being flicked inbetween - doesn't matter which? Is this correct. Just curious....Obviously for a 3 way lighting cct there are 8 combinations if you wanted to going running up and down the stairs all day..and if you had 2 sets of 3 way lighting on the same cct....
Reply to 2/3 way Lighting and IR test in the UK Electrical Forum area at ElectriciansForums.net
When you did the further testing and got the 0.06 reading were the CPC's back in the consumer unit? Really when testing you should leave the...
We just left it as it was, again the customer didn't seem too bothered, dont think she wanted me digging any further.
