2 bulbs light speratley | on ElectriciansForums
Discuss 2 bulbs light speratley in the Lighting Forum area at ElectriciansForums.net
pierrerio
Malta
Right now I have two ceiling lights that light together from a single switch. Now I would like to make them light seperatley, How can this be done please?
Thank you
Depends how they wired mate…..I’d assume they are wired in series in which case you’ll need to separate them and turn the current feed to the second light into loop in and you’ll need another switch drop cable or a wireless switch and receiver, quinetic is a brand…..either way I’d recommend an electrician sorry 😁
Thank you I have an idea how to do it I wanted to ask just to be sure . Thanks again
In SERIES, Eggy?
It may be an easy job, it may not. All depends how it was wired originally.
Right in saying Quinetic, or other Smart home solutions are available.
They won't be wired in series as they would be very dim if they were.
Reply to 2 bulbs light speratley in the Lighting Forum area at ElectriciansForums.net
In addition to Brians post above you can get electronic impulse relays, so no thud as they switch in and out.
Here are photos of the power supply unit, somebody told me I need a new transformer? Many thanks in advance.
