2 cables to each light switch | on ElectriciansForums
Discuss 2 cables to each light switch in the Australia area at ElectriciansForums.net
There are 2 cables each consisting of 1 red, 1 black and 1 earth wire.
are they connected in to any thing?I'm guessing that the 2 wires are connected to the switch and the blacks are connector blocked? Certain kinds of dimmer switches need a neutral,and sometimes its easier to wire this way for an outside light or wall lights,but most likely it was wired by a plonker.But I wouldn't worry about it as it has given you more scope for alterations and additions,without haveing to get to the switch again.:)
Thanks for the info. The blacks are all together in a block. Why is it done like that? Why not simply 1 cable with live and neutral?
You only need to switch the live of the circuit, normally you would feed the light fitting and only have one cable to the switch but in this case they have fed the switches, both ways are acceptable.
All the switches are the same - 2 cables, the blacks are all in a connector block, the reds are connected to the switch. I expected to see 1 cable with the black and red both connected to the switch. Can you tell why there're wired in this way?
Why would this be wired by a plonker?
This is a very common method nowadays with the amount of downlights fitted into homes.
Rather than have a joint box for the live feeds, switch wire and switched feed to the lights above the ceiling and in a room of say 10 lights, no indication as to its whereabouts, the joint is accessible and easy to test.
you don't switch the neutral,Don't lose any sleep over it! It could be a good thing---you could always convert your switches to pir's so the light comes on automatically when you walk into the room and goes off again when you leave.
Sorry, I still don't get it. Where does the additional cable run to? If there are 2 live, 2 neutral and 2 earth wires in each switch, why aren't there more wires in the ceiling rose
Having it all at the switch makes life easier, i will be doing it like this allways from now on. Just wish they would make switches that have space for the neutrals instead of farting about with connectors etc.
1 cable with the live neutral and earth comes from the consumer unit, then to the switch, then on to the lamp.
I'd expect to see 4 lives, neutrals and earths in the ceiling rose - 2 for the the cables running to the switch, 1 from the previous light and 1 to next light - that's not the case there are only 3 of each. Confused.
To make matters a little more complex, if the circuit was looped through each switch then there's normally three T&E's in each one all except the last, where there would be only two.
Whether its looped through the rose or the switch there are normally only three cables to connect, but switch loops take a single cable to the rose.
Reply to 2 cables to each light switch in the Australia area at ElectriciansForums.net
Thanks again for your help, now solved đź‘Ť
I am confronted by people with experience in using them for lighting circuits and sockets in a three-phase installation, as it is only allowed to...
