T
TALK
While inspecting a premises I have come across...a 3 phase cold room with 40amp mcb protection.The problem is...the supply cable is 2x2.5mm 4 core and a separate 4mm earth run along with the 2 cables.The 2.5mm cables are doubled at the mcb,(does this create a 5mm supply).
A 5mm supply cable will never carry 40amps if required,although circuit running ok.Whats everyones thoughts on this?especially 2 cables used for 1 supply.
