2 circuits 1 breaker | on ElectriciansForums
Discuss 2 circuits 1 breaker in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
G
guinnessgixer
Hi
Just wondering how you guys fill out the form when carrying out an inspection when for example there are 2 lighting circuits in one 6a breaker,
I've been seperating the cables working out which is supplying what and filling in the form as if they were seperate circuits but calling them circuit 3 a and 3 b on the form,
do you approve?
As above there is only one final circuit. What you are calling a second circuit is in fact spurred from your first circuit at the MCB and so there is actually only one final circuit.
Reply to 2 circuits 1 breaker in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Ok, please be aware that I am a 'do-it-yourself-er,' so if this isn't the right place to be posting this thread, let me know where I should be...
Thanks little spark. Good point but the drivers I'm considering have a sync and communication between driver function. So (as long as it works)...
