2 circuits | on ElectriciansForums
Discuss 2 circuits in the Australia area at ElectriciansForums.net
B
brightspark2010
High today at a fault call i noticed that on a row of lights that were out the swa that fed them was also feeding the other row so two seperate circuits fed via 2 seperate mcbs eg lives, neutrals+ cpcs all in the same multicore armoured i informed the client this would need rewiring with a new feed for the other row. However was just looking to see if anyone knew what regulation would back up my claim? Cheers
Thats what i was askinng is it acceptable for two circuits in 1 multicore cable then never heard of at college or seen in the last decade on site and to trevor this was definately two circuits not two rows on 1 feed
2 rows of lights with 2 seperate feeds = 2 circuits. It matters not that they are fed from the same multicore, 1 live to each row 1 neutral to each row 1 cpc to each row. As wirepuller said whats the difference between that and a bit of trunking with 2 circuits in it?
I've read the op properly now hehe
Oh cheers mate i was a bit worried when i saw it i know in pricipal its the same as numerous circuits in a trunking/conduit system just never seen two circuits down one cable and was a bit worried if it was ok just in case someone isolated 1 circuit and thought they had killed the entire cable.
"I've been having a bit of a think about that cable and I think we'll be OK because.........."
If you think about it, we use multicore cables for multiple circuits all the time - what else is YY? My background in theatre lighting is almost totally reliant on a long established practice of running six separate lighting or power circuits (L,N,E) down 1 x 18 core 1.5mm cable (Socapex).
Reply to 2 circuits in the Australia area at ElectriciansForums.net
We just left it as it was, again the customer didn't seem too bothered, dont think she wanted me digging any further.
Hello What was the conclusion of your problem?
