2 conductors in the same Wago connector hole | Page 2 | on ElectriciansForums
Discuss 2 conductors in the same Wago connector hole in the UK Electrical Forum area at ElectriciansForums.net
Bristol
I've just watched a video on youtube about installing a bathroom extractor fan off of the light switch.
In it the guy says how much easier this is when you use Wago connector blocks rather than a ceiling rose (about 7 and a half minutes in). He's using Wago 3-way lever connector 222 blocks, but of course 3 of the blocks need 4 connections, so he's shoved 2 conductors into the same hole.
Is this safe / ok? I guess 5-way connectors wouldn't fit in the box, and (as far as I can tell) they don't sell 4-way connectors.
Any advice much appreciated.
So you're going to need 3 x 4-way connector and 1 x 3-way connector, which will take up quite a bit of space. What kind of box would accommodate all of that?
If it's loop in (L/I), loop out (L/O), switch (S), light (L) and fan (F), you're going to need (these are standard size push connectors):-
1 x 6w (CPC - L/I, L/O, S, L, F)
3 x 4W (P/L - L/I, L/O, S, F) (S/L - S, L, F) (N - L/I, L/O, L, F)
They will fit quite comfortably in a standard Wagobox.
I doubt prof stephen hawking pondered this before his death. So the forum will decide....
Is it permissable to mix and match different makes of push fit connectors
Ie wago and them other ones by ideal as shown below and put them in the same wago box or other similar mf enclosure..
Even if not against the regs...is it a mortal sin?
[ElectriciansForums.net] 2 conductors in the same Wago connector hole
That's the advantage of screw terminals, you can shove whatever conductors you like in and then tighten down.
The other advantage is cost.
Even then, especially with 3 conductors, it's common to fail the pull out test after tightening the screw firmly.
No not a good idea to do what Matey did and yes you can get 4 way Wagos
I kicked over my, just restocked, wago box yesterday - it looked like a bag of 'pick and mix' until I could take no more and sorted them last night before bed!
Since using the wagos after discovering them on here, they are so very useful and keeping a stock is essential.
I was doing some light changes the other day and screw terminals 'were' the ideal connection so nice to have all avenues covered.
Reply to 2 conductors in the same Wago connector hole in the UK Electrical Forum area at ElectriciansForums.net
I believe the 6mm and 40A MCB debate is a little contentious at times. It depends on the installation method, being pretty close to the tabulated...
I've made the required tweaks on the junction box with a 4mm hole bottom, upturned wagos and reduced the exposed copper. I did originally install...
