2 conductors in the same Wago connector hole | Page 6 | on ElectriciansForums
Discuss 2 conductors in the same Wago connector hole in the UK Electrical Forum area at ElectriciansForums.net
Bristol
I've just watched a video on youtube about installing a bathroom extractor fan off of the light switch.
In it the guy says how much easier this is when you use Wago connector blocks rather than a ceiling rose (about 7 and a half minutes in). He's using Wago 3-way lever connector 222 blocks, but of course 3 of the blocks need 4 connections, so he's shoved 2 conductors into the same hole.
Is this safe / ok? I guess 5-way connectors wouldn't fit in the box, and (as far as I can tell) they don't sell 4-way connectors.
Any advice much appreciated.
I certainly would never do that. It doesn't take many brain cells to imagine that there is a high chance of a poor quality connection doing this, especially with solid core conductors as the dipstick in the video has done.
On a side note, anybody using wire strippers isn't a proper sparks :D
Agree with the first bit but I have used wire strippers for 50 years, quicker , easier and do not nick the internal insulation or the conductor so be silly not to use them.
Reply to 2 conductors in the same Wago connector hole in the UK Electrical Forum area at ElectriciansForums.net
I believe the 6mm and 40A MCB debate is a little contentious at times. It depends on the installation method, being pretty close to the tabulated...
I've made the required tweaks on the junction box with a 4mm hole bottom, upturned wagos and reduced the exposed copper. I did originally install...
