2 core armoured cables | on ElectriciansForums
Discuss 2 core armoured cables in the Talk Electrician area at ElectriciansForums.net
K
kiggie89
i came a cross a 16mm two core cable today and they want an other small supply taking off if. can i still use it? as i got told, you can only use the armor for an earth if the cable size is no bigger than a 6mm. i was thinking can i install an earth rod and RCD's to get round this problem
thanks
Reply to 2 core armoured cables in the Talk Electrician area at ElectriciansForums.net
I assume said contractor is part of a Part P scheme (NICEIC, Napit, few others..) in which case complain to them. They'll investigate (in theory)...
I think I've found the answers to my questions... I can just do a straight forward wiring i.e. connect the 3 wires from the armoured cable to...
