Sav
Hi everyone,
just reading and giving myself examples of cables etc to work out cable selection and volt drop ( I know its Friday, but I have to keep reading or I will forget )!!!
If for example you have an swa 3core (brown, grey, black), which , say your running to a supply from a DB board.
On pages 274 onwards, the copper conductors and volt drops etc, would you say the cable is a 1 two core cable, single-phase or 1 three or four core cable, three phase ??
The scenario is 60amp isolator , swa 16mm 3 core ( brown, supply, grey with blue sleeving neutral and black with green/yellow sleeving earth ). 45 meter run along building and in ground, single phase. Abient air temp 30 degrees, Ground temp 20 degrees
Its basically just to see that even though the swa is 3 core, one of the cores (black) will be earth and its single phase.
So what would you base the calculations on ??
Thanks and regards,
Sav
Thanks and regards,
Sav
