2 double switches for 2 hallway lights | on ElectriciansForums
Discuss 2 double switches for 2 hallway lights in the Lighting Forum area at ElectriciansForums.net
Widnes
I've got 2 double switches to wire for 2 hallway lights. Each switch has cable connecting to one light then cable between the 2 backboxes, which says strap on it. How do I wire the double switches so they can turn each light on and off?[ElectriciansForums.net] 2 double switches for 2 hallway lights[ElectriciansForums.net] 2 double switches for 2 hallway lights
you may find that it's been wired so that both lights come on together. can't be sure without being physically there with test meter/s.
On the first picture, what is marked on the left hand cable?
There isn’t enough cables there to have 2 lights controlled by 2 x 2 way switches.
pop the backboxes out the wall and check there’s no more cables hiding in the wall.
Reply to 2 double switches for 2 hallway lights in the Lighting Forum area at ElectriciansForums.net
Thanks again for your help, now solved đź‘Ť
In addition to Brians post above you can get electronic impulse relays, so no thud as they switch in and out.
