Hi... I moved house fairly recently and I'm slowly uncovering 'quick fix jobs' all over the house from paint, render and now electrics.. I came across some electrics in the garage and I'm curious to know why they've done what they have and is it correct in any way, shape or form (and safe?!) please? Be grateful for any advice anyone can offer me, many thanks.
They seem to have a feed from the Garage fuse box into the switched fuse spur on the left... then they cut a hole in the right side and run feeds from the L/N/E into the fused spur on the right (Ive tried to sketch it if it helps?)... that feed then comes out and runs to a double socket on the wall which then runs onto another double socket further around the garage... So I guess my question is what is the purpose of the second fused feed on the right and it seems to be almost an 'extension' of the fuse box on the left? Could I not remove the fused right hand and run the sockets straight from the switched fuse? The fridge in there runs from the socket not directly into any fused connection. Hope that makes sense? Thanks in advance..
