I
Itisonlyme
Hi all, new here and after some advice on a twin dimmer switch purchased from a large warehouse type diy store.
It is marked as a two gang two way dimmer, so I was expecting to find six terminals; one common and two switched live on each of the two sides.
Yet there is only one common.
Now, I am using it for what I think is a pretty standard use of replacing the two gang two way switch that controls; gang 1- one way control of lounge lights gang 2- two way control of landing light upstairs. I have wired it as prescribed by the instructions and it works fine. I have also added earths to the metal faceplate which were not present on the original metal switches!
So here is the question.....live is running down a red core of three core cable from upstairs and connected to the single common terminal, also connected to this terminal is the live side of the lounge lights downstairs. So surely if I pull the fuse to isolate upstairs (though I always switch off all power) lights the switch will still be live upstairs courtesy of the live being supplied from the downstairs supply to the lounge?
I did originally connect all the cables as they had been connected in the original switch which had two commons but this resulted in the light not being switchable from the other location/staying on when the should have been off e.t.c.
Is this arrangement allowed?
Grateful for any advice.
