2 Gang Dimmer Wiring Help | on ElectriciansForums
Guest viewing is limited
Discuss 2 Gang Dimmer Wiring Help in the UK Electrical Forum area at ElectriciansForums.net
Simbo
Essex
L Good evening,
I’m hoping someone might be able to help me with wiring up a dimmer switch.
It’s a 2 gang IR dimmer. One of the modules in the previous switch became faulty so an electrician friend of mine wired up both lights to one module as a temporary fix. I’m a little confused with what goes where in the new switch.
A cluster of cables on the right has 2 brown live wires and 2 blue neutral. The cluster of cables on the left has 1 brown live and 1 blue neutral. I’m wondering why the right side has 2 of each?
Any help would be much appreciated.
[ElectriciansForums.net] 2 Gang Dimmer Wiring Help
As per #3 leave the link between the two in place and separate the two on the far right leaving one in place and move the other to the corresponding terminal of the other switch.
Reply to 2 Gang Dimmer Wiring Help in the UK Electrical Forum area at ElectriciansForums.net
Brilliant thank you so much for your help 😊 x
Ah yes my apologies, thank you much appreciated.
Recommended Sponsor News
Hi everyone,
