P
philbo
The problem i am facing is mainly safety related.
I have 2 rooms working off one 2 gang standard light fitting.I want to install a 2 gang dimmer.
Ok so i removed existing front plate off light fitting. 2 earth leads correctly attached to backplate.all four wires are brown with 2 going to each gang in L1 and L2.
So I open dimmer and the fitting screws to each gang are (wavyline/arrow and L1, L2 )
The wiring is very easily disginguishable for each light...so do I fit each light to the corresponding L1 L2 of the dimmer or place one of the wires into (wavyline/arow ) and one to L1.
I say its a safety issue as the children will use the light and i want it wired correct.
