2 gang DP light switch | on ElectriciansForums
Discuss 2 gang DP light switch in the UK Electrical Forum area at ElectriciansForums.net
E
Eddiesparks
Hi guys, quick one,
Anyone know where I can get a two gang double pole light switch that will go into a single box? For outside lights . Without using grid. Neutral run to switch. Search Google and fleabay and all I got was 2G sockets and two gang two way switches!
Cheers boys! And a merry Christmas one and all.
Telectrix spot on. Good to isolate N too in case of a N-E short.
I think i'll have to go grid then. Grid can get a bit expensive which is why I am not so keen, i'm being a skinflint!! But actually a 2G DP switch will prob be dearer!
Thanks lads
Reply to 2 gang DP light switch in the UK Electrical Forum area at ElectriciansForums.net
Double pole switches? Mounted on a grid module? Ignore the fact they have a N stamped on them. Or is your 2 gang switch decorative, and you...
Interesting that Avo 8 has brought Legrand into the conversation, as it certainly could be done with the Legrand IP55 switches I've used for about...
