2 gang light switch with fuse holder | on ElectriciansForums
Discuss 2 gang light switch with fuse holder in the UK Electrical Forum area at ElectriciansForums.net
i need to replace a 2 gang light switch but its got a fuse holder next to the switches with a plug top fuse in. its not in a grid format just a normal 2 gang switch on a single plate with the fuse older. any one know where i can get one from?
[ElectriciansForums.net] 2 gang light switch with fuse holder
heres a picture of it
You need to get a 1 gang triple aperture made by click (all different colours) with a FCU module and then two 1 or 2 way switch modules to suit colour...your local wholesaler may do the 'click' range :)
Reply to 2 gang light switch with fuse holder in the UK Electrical Forum area at ElectriciansForums.net
Double pole switches? Mounted on a grid module? Ignore the fact they have a N stamped on them. Or is your 2 gang switch decorative, and you...
Interesting that Avo 8 has brought Legrand into the conversation, as it certainly could be done with the Legrand IP55 switches I've used for about...
