2 Generation Meters? | on ElectriciansForums
Discuss 2 Generation Meters? in the Talk Electrician area at ElectriciansForums.net
M
metro.solar
Hi All,
First post on the forum.
I am wondering where we stand when we install a PV system on 2 seperate roof elevations, with 2 seperate inverters, but 2 meters? Can we register 2 meters with the MCS and with energy suppliers?
Thanks in advance
I would run a 6mm or 4mm ac cable run depending on distance from each inverter both back to the meter at mains position and connect together in the meter, then from the meter to the isolator then to the 16 amp mcb in the c.unit. Still only 1 meter.
When you register the job with mcs there is only one box in which to type the serial number of the meter, So Im not sure Sorry!
I dont see any reason why you would want to use 2 meters really, unless you want to see if one array is generating more than the other,
in which case if you use 2 SMA inverters, the displays would tell you.
Reply to 2 Generation Meters? in the Talk Electrician area at ElectriciansForums.net
https://www.amazon.co.uk/gp/product/B08CJ3VC79/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1 I use this, current clamps go round each outgoing...
N
Looking for a smart water meter I live in Azerbaijan and am looking to revamp the water system in my house. The first thing is that I don't have a...
naylorpd
N
