2 ovens on same radial | on ElectriciansForums
Discuss 2 ovens on same radial in the Australia area at ElectriciansForums.net
damien1
im doing a job in a kitchen this week that as no existing cooker radial my question is
can i run two ovens rated at 3.650 and 1.900 on the same 6mm cable
if so would these need two separate 45amp cooker switches fitting
and also should i take diversity into account and im also a bit confused as to what size mcb should be used
i am qualified to 17th edition but not bein in the job for a few years can anyone offer advice
cheers
before i went to look at the job i was planning to put two radials in but they was no room for an additional circuit im having to remove the circuit for the basement to make room in the c u for the cooker radial the guy cant afford to have a new c u fitted
Reply to 2 ovens on same radial in the Australia area at ElectriciansForums.net
One thing you may find is that it will most probably be a 6mm cable and to get two of them in to a terminal may prove to be a stumbling block if...
I have to agree with Baldelectrician on almost everything he says except one ! I wouldn’t be walking away I’d be running lol. Definitely if your...
