2 phase weilder | on ElectriciansForums
Discuss 2 phase weilder in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
been asked the question, why is only one of his three phase meters, spinning faster, when the weilder is used, when it has a 2 phase supply?
never heard of or used a 2 phase welder, but to hazard a guess, perhaps the welder uses a transformer with a 400 V primary (this would mean connecting 2 phases), and some other useful secondary voltage. if you connect L1 and L2 to the primary winding, say L1 to the 400V terminal and L2 to the 0V terminal i would imagine L1 meter to spin whilst not the other 2 with the welder in use as the power has been used. alternatively i might be imagining this
:confused5:
thanks pmac10, i think that is how it is working, one of the phases is acting like a nuetral, which does not get recorded on a meter. the welder in question needs a 65kva, supply.!, there is only a 60kva supply to the building, but they tell me it only works for 10 seconds at a time.
Reply to 2 phase weilder in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Thank you
Has the cover been removed, is it TP bussbar? I fitted one as @oscar21 linked to a few months ago, it was actually a nice board and with the TP...
