2 pin ballast (choke) wiring | on ElectriciansForums
Discuss 2 pin ballast (choke) wiring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
suneth
I have 400W Metal Halide bulb, Igniter and a 2 pin ballast, Can someone explain how the wiring should be done done in order to start the bulb.
Reply to 2 pin ballast (choke) wiring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
You really need an inductance or LCR meter or a ring tester which are expensive to buy but you can make your own ring tester if you want a project...
Hi, I am restoring an old art deco, wall mount medicine cabinet. The cabinet has an 18” fluorescent light tube on each side. Before I put a lot...
