2 questions I messed up on my 303 .help! | on ElectriciansForums
Discuss 2 questions I messed up on my 303 .help! in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
N
Noom
Anyone know the answers to these
What RCD test do you perform for detecting nuisance tripping?
What is the maximum csa cable that can go through a hole without needing an enclosure?
cheers
cheers
You sure that enclosure question is correct?
I had something like what is the maximum permissible gap around a cable as it passes through a wall/floor. The answer to that is 527.2.1 ;)
Upvote 0
Can't remember the exact wording but i'm pretty sure it was about the CSA of cable allowed,and it it also mentioned enclosure and non-fire protected,but you may be right.
Thnks for that T@E. That sounds about right.I put 0.5 x current rating which can test for earth leakages,but probably wrong.
Hopefully I got about 60-70% so I may have scraped through.Got 86% in my 302 and dist in 301
Upvote 0
Reply to 2 questions I messed up on my 303 .help! in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
word of caution, the federal electric breakers are old bits of kit. I have known them sometimes to refuse to turn back on if they are tripped or...
I can't help wondering about earthing arrangements and how important aesthetics really are when attempting to make the best of a less than ideal...
nicebutdim
N
Electrical Courses
