View the thread, titled "2 questions" which is posted in Solar PV Forum | Solar Panels Forum on Electricians Forums.
G
glen7
Can someone answer?
when installing solar, do you conect all the wiring on the ac side as if you are treating the panels as the load. thru rcd, mcb etc
when connecting to the gen meter do you conect the solar panel side of wiring to the supply on the meter?
Thank you
Reply to the thread, titled "2 questions" which is posted in Solar PV Forum | Solar Panels Forum on Electricians Forums.
