2 radials on 1 MCB | on ElectriciansForums
Discuss 2 radials on 1 MCB in the UK Electrical Forum area at ElectriciansForums.net
N
Newbie90
Hi all,
I have tested a consumer unit and found that there are 2 16a circuits with 2 radials on each.
One circuit feeds 1 DSSO in utility room and 1 DSSO under the stairs ( 2 radials)
The other circuit feeds 2 DSSO in bedroom and 1 DSSO in kitchen (2 radials)
There are no spare ways in C.U to split through radials.
Do they need replacing with 20a MCBS?
has there been any problems with MCBs tripping? if not, then stick with the 16A ones. better to have an occasional trip than for cables to be overloaded.
Some wallys I work with downrate all ring mains installed to ref method 101 on to 16amps (even though we could get away with 20amp rings).....
Occasionally on these social housing properties you find a old granny who wants to do her washing, tumble drying & and boil the kettle at once and we get called for it tripping the 16amp.
Social housing contractor i was subbing for until I'd had enough recently did wire 4mm RFCs on rewires, all in trunking and clipped up on batten above the fibreglass, when we did any remedial works to a property any 2.5mm rings would be downrated to 16A. all lighting circuits in 1.5mm, max of 6 points per circuit, bit over the top!
These are existing installations.
We do a lot of EICR's for a major social housing company, they have there own suggested coding sheet of what's a code1/2/3 etc, and cables installed to the ref method 101 is a code 2 with them, which I find silly considering all the ECA advice is to let the inspector use his discretion as to if there is thermal damage etc.
So on a typical day I turn up to test a 1 bedroom bungalow, with at least 300mm of insulation buried on cables; I will downrate the ring to b20, and if the shower and cooker are in 6mm, I have Rewire the whole circuit, clipped around the beams, with CT4 trunking drops to support the cables ( they want all cables in a loft clipped 250mm and supported where they drop).
To say all of this does my head is a understatement!
True about the coding, I can't see how they deem unsupported cables in a loft a code 2, it's a inaccessible location technically, so the clipping distance tables shouldn't reply.
Reply to 2 radials on 1 MCB in the UK Electrical Forum area at ElectriciansForums.net
Joining the ends of the radials together to form a ring, and changing the circuit protection to a single 32A would solve the MCB overload problem...
