2 rooms 1 fan. | on ElectriciansForums
Discuss 2 rooms 1 fan. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
T
TyBrent
Hi guys,
what at is the best way to wire 1 fan controlled by 2 light switches in separate rooms?
Thank you in advance!!!
Ty
2 rooms 1 fan .....
Damn thought this was something completely different ... Oh! thats 2 girls ..........my mistake!
DP switches or you can come off the switched side of the light via a relay / contactor
Reply to 2 rooms 1 fan. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
The 2 inputs are separate and there should be no interlinking between SL1 and2 If there is there has to be a wiring error or a fault with the...
I have three 6" LED wafers and a ceiling fan on the same circuit/switch. I wanted to control them separately, so I installed GOVEE smart lights...
