2 strings minimum number of panels. | on ElectriciansForums
Discuss 2 strings minimum number of panels. in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
M
Mhairi
We have been asked to design a system 14 panels on South 2
panels on West. What is the minimum amount of panels
on one string? Not convinced that west panels will get enough
daylight to activate?
Novice123
Sou what would be the best thing to do?, just not to put the two on the west side as it will just degrade the array so will be of no benifit?.
was looking at a house the other day with this kind of setup and was wondering how they designed it and how i would?
Cheers
Grand
Soladin 600.
With the extra switch gear, wiring etc your better off making the best out of the southern roof. Maybe use Sanyo panels if your tight on space.
Reply to 2 strings minimum number of panels. in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
If the batteries are charged and the house is taking little then the full production of the panels will be dumped into the grid. As you have set...
Hi all, This may is a little odd and may take some getting your head around but here goes... I measured around half the load current on two DC...
