I carried some work out today in a property in a block of flats, just installing a fan in a bathroom. whilst carrying out some tests I noticed an MCB in the DB marked coil. After some investigation and discussion with the owner it sounds like (I can't be certain)
This MCB feeds a contactor in the communal service cupboard which in turn feeds her storage heaters, so effectively her storage heaters aren't fed from her own supply. I couldn't gain access to the service cupboard as it was locked and i couldn't obtain a key at the time.
My question is in the event of a fault could this create a dangerous pd across the casings of the storage heaters?
Cut out was located inside the flat
tn-cs
tn-cs
