Hi Guys,
I've just looked at a heating system which has a few issues like immersion stat faulty.
This is the current set up -
Upstairs has H/W tank (that also feed downstairs) and heating both fed via a 3 port valve to a pump down by the boiler.
Downstairs has heating fed via a 3 port valve but with only heating side wired on the valve back to a second pump by the boiler just for downstairs. The port 'B' on the 3 port valve is plumbed but I have a feeling it doesn't go anywhere but haven't traced it. I've shut off a valve on this leg to see if anything stops working.
The client says rads are heating up with all programmers switched off.
The main issue is the boiler is on permanently and the only way I can see to control the boiler is through a relay.
Is there an 'off the self' relay box to connect both pumps to switch the boiler?
