2 way circuit diagram | on ElectriciansForums
Discuss 2 way circuit diagram in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Leicestershire
how do, we have been asked to do a 2 way circuit diagram for an assesment at college, does this drawing look right? ( hopefully i can upload the pic :confused: )
[ElectriciansForums.net] 2 way circuit diagram
cheers for any help
You don't link the 2 commons together, one common is live in and the other common should be live to the light fitting.
L1 links to L1
L2 links to L2
Dont forget to have an earth at the light fitting too.
Hope this helps
Upvote 0
your live feed from mains to the Loop Loop to Common on first switch L1 and L2 on both switches Linked ( strappers or Pass wires ) depends where you live what they are called Common from switch number 2 to the Sw Live on the light fitting neutral to neutral
you have connected the live feed to the swlive at the fitting and the commons shouldnt be linked as your diagram shows Hope this helps
Upvote 0
You would do switch live to L1 and common to L2 from ceiling rose then from switch 1 to switch two three core and earth would be used and then connect L1 to L1 and L2 to L2 then common to common and your earth is connected in backbox you would do it like this in twin and earth no crimping done at all. My dad showed me this he has 50+ years experience and my tutor did not even know this he had us crimping. I don't understand how people are saying you can't link the commons ?
Upvote 0
the live wire from the mains goes to the common terminal of switch 1 and L1 and L2 of switch 1 go to L1 and L2 of switch 2, the common terminal of switch 2 then goes to the lamp while the neutral goes directly to the lamp. hope this help
Upvote 0
Reply to 2 way circuit diagram in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Your parts list seems somewhat non descriptive. Plastic single box should be one gang stating it's depth. Metal couplers, what size? Metal fuse...
I did the homestudy level 2 and level 3. You're on premesis for 4 weeks for level 2 and 3 1/2 weeks for level 3 broken up over the time you take...
Electrical Courses
