2 way help (LOL) | on ElectriciansForums
Discuss 2 way help (LOL) in the UK Electrical Forum area at ElectriciansForums.net
B
boycie
on a new build housing development.
2 way across hall
fed at switch with 3 core going to other switch and then switch line from that switch to light. so i have 2 feeds and 3core at 1 switch and then 3core and switch line at the other. never seen it done like this not sure if it will work ? anyone know how to connect it?
2 way across hall
Feed into common in switch one, two strappers over to switch 2, and you'll have to take the neutral over on your 3rd core of the 3C, switch line out of common on switch 2
Reply to 2 way help (LOL) in the UK Electrical Forum area at ElectriciansForums.net
Furthermore, as the left hand switch will currently not do anything, I'd try the loose brown in here:
Ah yes my apologies, thank you much appreciated.
