2 Way Light Switch Driving me Crazy!! | on ElectriciansForums
Discuss 2 Way Light Switch Driving me Crazy!! in the UK Electrical Forum area at ElectriciansForums.net
M
Marc England
Hi Everyone,
Ive been having a nightmare when trying to install a new 2 way light switch in my house,
I currently have normal single gang 2 way light switches in my living room, on one of them there is a C terminal, and L1 and an L2, with 1 wire going to C and 2 wires going to each of the L1 and L2 terminals. on the other light switch there is a C terminal and a L1 and L2 and there is one wire going to each of these terminals.
however, i want to replace these with 2 Livolo touch screen light switches, on these switches they have a C terminal and an L1 terminal but then they have a signal A and a Signal B terminal,
Ive tried google and cannot find anything,
any help would greatly appreciated for my sanity's sake!!
Thank You
Marc :smile5:
what you will probably find is that they need a permanent live and neutral in order to work (not able to look those units up at the moment). In which case, the send A and B replace the L1 and L2 (I guess) but you might struggle to make yourself a permanent neutral without doing some rewiring.
Hi
The instructions shows a diagram of the two light switches, on one of them it shows Live going to the L terminal and on the other it shows a neutral going to the L1 terminal and then connected together via the Signal A and Signal B terminal
Hi,
this is the diagram from the instructions
[ElectriciansForums.net] 2 Way Light Switch Driving me Crazy!!
No neutral needed at either switch. The 2 core and 3 core between the switches are ample for what’s required.
Give me a few minutes and I’ll knock up a drawing.
Looks to me like one of the switches is fed with a permanent live and is joined to the other switch via the Signal A and Signal B (L1 and L2 in a standard 2 way switch) and then feeds the light via the L1.
This would be the same as feeding the common of one switch, joining the switches L1 and L2 with T&E and then feeding the light from the common of the other switch.
Reply to 2 Way Light Switch Driving me Crazy!! in the UK Electrical Forum area at ElectriciansForums.net
Thanks again for your help, now solved đź‘Ť
"It works" and "it's safe" are not necessarily the same thing. With DIY work, they are often far from the same thing.
