R
rapidrich
hi i have a 2 way lighting circuit at the 1 switch it is perm live to com then a strapper from l1 to l1 of the other switch then then one from l2 to l2 and then com of the other switch goes to the light should in theory this work?
Sounds like conventional 2 way switching and should work fine, only concern is that if its wired in twin + e there may be some unused cores, normaly this type of wiring is only used in conduits and in a corridor.
Hope this helps
AJ
Hope this helps
AJ
its made up of its made up of single live perm + switched plus a twin connectin th 2 switches
thats ok would one of the switches cause a prob being a dimmer switch because i wired that way but it would not work properly?
As long as its a 2 way dimmer it would be fine jsut double check connections and remember the common on the dimmer is some times marked up as a wavy line?
2 way lighting (dimmer)
Australia
rapidrich,
sparks1234,
