2 way lighting fault - in steel conduit | on ElectriciansForums
Discuss 2 way lighting fault - in steel conduit in the Australia area at ElectriciansForums.net
J
Johnny-G
I was looking at someone's hall lighting the other day as neither of the fittings work.
It's 2 way with 2 fittings in an apartment all wired in singles in steel conduit.
There's power to & leaving switch A but no power at either fitting or switch B so there must be a cable break somewhere, only thing is that it's in steel conduit so how do you find the fault?
I don't normally work on steel conduit installations but was having a look for someone as a favour, stupid idea that was.
Singles in conduit - lucky you! Check for continuity and resistance and you should be on your way (especially if you are able to pull the singles through). Bare in mind, with steel conduit, it would take a serious drilling in the wrong place to cause damage to the singles.
Regards.
There’d have to be two breaks. One in each jumper. I’d go back and test again.
There's definitely no power at either fitting or switch B.
No intermediate switch.
No DIYing although I asked if there had been any work going on in the flat upstairs and apparently that's being refurbished but the builders would have to be seriously mad to drill through concrete floors although vibrations might've loosened something.
I've searched for a JB but can't find one, is there likely to be one as part of the conduit system which is plastered in?
Not unheard of to have JB's plastered in. I would also be retesting before doing anything else. Label everything up, disconnect it all, and con check every cable, and whilst you are at it do an IR test, and dont overlook faulty switches especially after a short circuit fault, but con check and IR tests should highlight where the problem lies. Does the live supply come in at one of the switches, or does it go to a hidden Jb somewhere that you cannot locate? Have you confirmed your neutral continuity?
Cheers............Howard
dont write them builders off!...ask when the fault first started.....then once you have a starting point....go ask them builders when they started banging and braying....probably drillin n all.....but dont let on your a sparky up front to em will you..lol......wont get owt out of em then..lol.....
Reply to 2 way lighting fault - in steel conduit in the Australia area at ElectriciansForums.net
Thanks again for your help, now solved đź‘Ť
Not to mention welding switch contacts together and wondering why when they thought they had got the wiring sussed the light will still not switch...
