2 Way lighting in bathroom | on ElectriciansForums
Discuss 2 Way lighting in bathroom in the UK Electrical Forum area at ElectriciansForums.net
VWWM 1
Hemel
Err why have I just seen 2 pullcords in a bathroom for 2 way lighting. 1 directly above the bath measuring 2000mm from the bottom of the bath?
Never seen that before!!
Are you sure it’s for the lighting?
could be an extractor fan, shower isolator or panic alarm?
Definitely 2 way I checked it. And there is another 1 next to it for the fan. Which has been used to add a switch to a ELV fan wired in singles between the fan and other Pullcord.
the fan is so old it has the transformer sitting above the surface fan built into it 240v in zone 2 (No earth connected) that steps down to 12v inside the fan.
must be 40 years old but still works!!
That's all too much work, just run a really long pull cord around the room through a load of eye bolts.
My father invented a version of this, some decades back, where a pull cord was wall mounted in an outbuilding, nowhere near either door.
It never struck me as particularly good design, but after reading this thread I'm gutted at the loss of future royalties from his lack of foresight in not applying for a patent.
Reply to 2 Way lighting in bathroom in the UK Electrical Forum area at ElectriciansForums.net
There is also the ongoing problems if this is a gendered changing room.... For example, 2 or 3 burly male soldiers (you said it was an officers...
ok cheers for the help lads
