2 way lighting, PIR motion activated | on ElectriciansForums
Discuss 2 way lighting, PIR motion activated in the Australia area at ElectriciansForums.net
I
IanC
Hello All,
Is it possible to include a motion sensor into a 2way lighting circuit?
If so, how would you go about the wiring?
There are switches at the top and bottom of some basement stairs. The occupants are keen to include a motion sensor as they sometimes stuggle to find the switch when entering the house via the basement. The live feed is in the switch in the basement.
It is possible, it probably would of been easier if they had perm live and switch live at the light rather than the switch. You will have to try and get the switch live, permanent live and neutral to the pir. Hope this helps
There IS a perm live and switch live at the light after all! What next???
Reply to 2 way lighting, PIR motion activated in the Australia area at ElectriciansForums.net
That will work fine as long as the Pirs use relay switching, some don't.
Smart switch 2-way operation is often achieved by the second "2-way" switch actuating the first "2-way" by RF (the first actually doing the...
