stevie gill
I have been asked to do a quote for an 8kWp system on a commercial building which only has a single phase supply.
After running different systems through various software it seems that I have 2 options;
1) Install 1 SB7000HV inverter
2) Install 2 x SB4000-TLs
Option 1 is the most cost efficient solution, but Option 2 gives a better overall yield and the cost difference is negligible.
Obviously Option 2 would be the best solution, but my only concern is regarding connecting the 2 SB4000's. Is it OK to run 1 AC supply from the DB and onwards as follows: AC isolator - Generation Meter - Junction Box. Then AC Isolator - Inverter 1 - DC Isolator and a repeat for Inverter 2? I have connected 2 SB1200's in this manner before, but wanted to check about the more powerful systems before proceeding with my quote.
If this isn't OK, what other options to I have - individual supplies to both inverters? How would you then connect the generation meter etc?
As ever, any help would be greatly appreciated!
