Discuss 20 Amp DP switches in the Talk Electrician area at ElectriciansForums.net
disagree. the 20A switch's load is limited to what you connect to it. obviously, you would not connect a load exceeding 20A.
So connecting one to a circuit protected by a 30/32 amp fuse or breaker is not allowed even if used as a switch for a single socket ?
Reply to 20 Amp DP switches in the Talk Electrician area at ElectriciansForums.net
