20 volts at light fitting when switch is turned off | on ElectriciansForums
Discuss 20 volts at light fitting when switch is turned off in the UK Electrical Forum area at ElectriciansForums.net
Leeds
Got a bit of a head scratcher!! I have a 2 way lighting circuit, if you turn the lights on with one switch then turn it off with the other switch the LED lamps will stay on very faintly (this is annoying the customer, which is why he called me out). When I checked with the multi meter it is showing 20 volts left on when the switch is closed. Any ideas what this could be? Thanks in advance. p.s does anyone know why I can't put paragraphs into the text anymore?:93:
I'd do a bit of a search on the forums - there's a number of threads about this. Check out inductive pickup, snubber circuits, etc. Daz
Reply to 20 volts at light fitting when switch is turned off in the UK Electrical Forum area at ElectriciansForums.net
Thanks davesparks. Looking at the diagram on the driver that's what I interpreted too, but I heard somewhere that the DALI system doesn't like...
Just doing some thread admin :)
