20a DP switch spur for 6 sockets | Page 3 | on ElectriciansForums
Discuss 20a DP switch spur for 6 sockets in the UK Electrical Forum area at ElectriciansForums.net
G100917
g40
Hi everyone, I'm currently upgrading my workshop and before I get quotes for the electrics I'd like to understand it better myself. If I want 6 sockets from a ring mains circuit can I spur off an existing socket to a 20a DP switch and run the 6 sockets from that? It's unlikely the load will exceed 4kw, there will be an electric heater running, as well as a kettle, microwave and occasional use of electric saw etc. Or would I be better off running 3 sockets each from two separate 13a FCU switches spurred off two different sockets on the ring circuit . Any advice would be appreciated many thanks.
Reply to 20a DP switch spur for 6 sockets in the UK Electrical Forum area at ElectriciansForums.net
J
The rcd spur being fitted is probably because there wasn't rcd protection of that supply.
K
Ah, I see. The op question is ambiguous, and I took it that he wanted to add a socket for a washing machine from and exiting switch fused spur. A...
