20A isolator switch in shower circuit. | on ElectriciansForums
Discuss 20A isolator switch in shower circuit. in the UK Electrical Forum area at ElectriciansForums.net
E
essexman
Having trouble with a isolator switch.
Fitted 20A D.P isolator switch in a shower circuit and the switch has failed. This is the second one I've fitted of the same type as the first failed aswell.
Shower is 8Kw. Should this happen, or should i have fitted 45A.
Any ideas,
Thanks.
you have to consider your supply voltage, from your supply voltage you calculate the current that your circuit takes. the current needed by the circuit should not exceed the rated current of the isolator. if the current needed exceeds the rated current of the isolator, change the isolator to one with a bigger value.
Come on guys give the guy a break, the 20A switch is probably flush in the nice new bathroom next to the flush mounted light switch and those 45A ones can be big and ugly looking.
Reply to 20A isolator switch in shower circuit. in the UK Electrical Forum area at ElectriciansForums.net
Hi, i am wondering if anyone has any experience with a 7.5-8kw shower that has a pump or some sort of boost internally fitted? Working at a hotel...
Hi all, first post, please be gentle ;) Iv been involved in a bathroom refurb, nothing major, moving a light fitting and switch. My problem came...
