Why does a 20amp RCBO come with only a 1.5mm neutral flywire when you are driving a 2.5mm power circuit. Aren't you creating a choke, & potential voltage drop. I appreciate it can carry 20amps but it doesn't make sense to me
Discuss 20amp RCBO neutral fly wire only 1.5mm in the Australia area at ElectriciansForums.net
Reply to 20amp RCBO neutral fly wire only 1.5mm in the Australia area at ElectriciansForums.net
