I am looking for some sensibly priced thread convertors so that I can screw my 25mm compression glands to the convertor/adaptor to then use the existing 20mm holes. On Andersen chargers there is a 20mm hole for cable entry and its a very tight squeeze to get a drill or cone drill bit in to enlarge without risking damage to the plastic core, its the sort of plastic that would under the right tension/force just crack
Was using a pile of Wiska ones but my suppliers are now saying out of stock or ÂŁ2 ex vat each... which for a bit of plastic seems excessive
AM i missing something obvious - have thought about a metal fixing but not found somebody with stock.. suggestions and suppliers welcome
