Don't do much conduit work...finishing my garage wire up and socket conduit needs to hopover the light circuit conduit. Can you buy these ready made or is it a case of bend your own?
*tin helmet on*
*tin helmet on*
Discuss 20mm PVC conduit crossover / hopover? in the UK Electrical Forum area at ElectriciansForums.net
Small adaptable box
Notch the back to fit over the lighting conduit
Bring the socket tubes to each side of the box at wall level.
No bending required.
I quite like this idea...novel thinking
Gives you some thing to stare at for 5 minutes and be proud of
LOL you do know that plastic conduit bending with spring is all about hands, not to say you can't with knees, I bend steel with the legs of the bender too. (tip for you)You must have a fair pair of hands to do that without bending it over your knee! Or are my hands a bit small?
Struggling to picture this... How do you manage that?I bend steel with the legs of the bender too. (tip for you)
They are..mainly as the lights are broken up (to allow me to have light while fixing another) and it results in that 20mm being on the full size..
Got the spring already, just a matter of time saving, why spend the time bending it when you can buy off the shelf...
Reply to 20mm PVC conduit crossover / hopover? in the UK Electrical Forum area at ElectriciansForums.net
